got spark and its not flooding?could be the distributor? have you check for a spark? or maybe its flooding
done fuse check,there is no error codes,its got spark just wont start,garage could'nt put it on diag machine,said it might be the chip in key,then it was the imobiliser,now the throttle body,but also said might be ecu????
does run for a few seconds when a little fuel is put in the tbdoes it run for a few seconds if you drop a little fuel down the throttlebody ?
if the injectors have a 12v supply, then most likely a nats problem
nats for sure eh http://www.micra.org.uk/threads/starting-problems-new-to-forum.50303/#post-510923i have done the paperclip test and it comes up with 141 and 142 after i changed the throttle body
tried most things,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,ame he just havin a bad run with him...
yep
try a ignition switch first, its cheaper.
the ignition switch can be removed from the end of the barrel np, and Ed on here is fusion motorsportHi,
Do you have a link for the ignition switch, can that be replaced without touching nats system? Also a company called fusion motorsport say they sell a new ecu to replace nats ecu any feedback on these?
thanks.
does anyone know where ther best place to get ecus from? for a micra k11 97 1.3 sr?
they took off my previous listings sorry,somethink about not being able to advertise selling it,bit harsh,as didnt know the rules....
I Have the same situation coming up. but gonna have to let it go.thanks i don't really want it to go. it was a incredible car
