PollyMobiles Rebuild
just a brief update summary.
these last two trackdays has been the best bday fun eva and the car setup has been successfully dialed in to perform how I like it.
I'm back home now still in one piece, me n the car really really worn out.
there's a huge amount of video n data to collate n assess over the few days ;)
It took long enough to do it but got there in the end :)
Now make those flipping notes
This is one of those times where I'm waiting for your posts on this @pollyp can't wait to watch your footage from the track :cool:
I've been editing, uploading & analysing the huge amount of video footage & notes n data for the past few days hence no posts yet cos I haven't finished analysing everything.
all the videos were finished n uploaded yesterday as andy says (i recommend the directors cuts :p) but have yet to write description as well as finishing my notes.
will post my report all in one go soon once all the vids, descriptions, photos, full assessment are in place. that way it keeps it all neat & organised in one place rather than posting fragments asap and having it scattered inbetween ppls posts.
ok to keep things in order on topic,
on my last post about the catch can, I reprinted the mount with the screw tensioner at the far end to make it more rigid. Mounted it on the morning before setting off and it’s a lot stiffer.
After blyton park I thought it would catch a lot but found not a lot had condensed?
Investigating further, what I found was that for the hot oily vapours to cool & condense inside the cans, the metal cans themselves would also need to be kept cool in the first place, like breathing on a stone cold windscreen in the morning, simple physics.
Now previously I briefly tied the PCV catchcan near the cooler area behind the LH headlight while the PCV breather catchcan was mounted on the boost pipe behind the hot radiator.
The hot air from the radiator would actually heat up the PCV breather catchcan and so if the can was no cooler or actually hotter than the oil vapours, nothing would condense inside.
Meanwhile the PCV catchcan in the colder airstream behind the headlight away from the radiator stream was a lot cooler than the hot oil vapours therefore 25ml of oil vapour had condensed on the cool walls after 300m
On the current configuration mounted down low right behind the rad, both cans would be heated up by the hot air on or off track
so when I opened them afterwards, the PCV catchcan only caught a little bit
and the PCV breather catchcan none at all cos they were both too hot
The weak fibrous strands of 3d prints doesn’t work very well with slippery oil vapours and would break apart so I’ll need to look into a more solid construction.
Thought about using this glass coffee jar which was the right size n shape and can see the content through the clear glass. The flat lid will have a 90deg elbow screwed on to clear the bonnet.
Either mount the pair on a metal bracket here behind the headlight
Or best place is in front of radiator to get really cold and condense as much vapours.
2015-04-09 Blyton Park
Set off from early 5am, arrived 8am on a nice calm sunny day. It was already ½ full and don’t see any micras so parked amongst the civics, caterhams, lotuses, trailers, etc registered, began unloading when Alex arrived, hullo :)
We both moved n parked at the end, unloaded, swapped over to 595RSR, set cold pressures same as last time in November 2.5/2.7bar f/r, always so much to do but not enough time. 9am drivers briefing then went for a sighting lap.
9:30 Outer Circuit Sight Lap -----------------------------------------------------------------
Before:
Setup:
Dampers: 15/30 F/R
Tyres: 595RSR 2.5/2.7bar F/R
Weight:60% fuel, me & dad​
Warmed up the tyres n brakes and then recheck & correct the tyre pressures.
10:00 -------------------------------------------------------------------------------------
Before:
Setup:
Dampers: 15/30 F/R
Misc changes:
  • Brake bias 75/25 F/R
  • Topped up oil that was lost on way to blyton park
During:
Track Condition: dry & hot
Track feedback:
  • loose item sliding around the floor
  • high grip
  • high traction
  • unable to lock rear tyres with 50/50 bias
  • heel & toe hard braking for The Wiggler not slowing enough (soft shoes & touching throttle)
  • after swapping input shaft & new LSD, the synchro for 3rd/4th gear are now engaging faster
Track Times:
1:31 traffic
1:27
Was annoyed by some loose object sliding around the floor so pitted soon after, found it was my foot pump hiding under the seats which I thought I’d lost in the morning.
@07:37 whilst activating the suspension cam I noticed some oil spray on the scuttle panel & windscreen & smelt oily exhaust vapours, oil catch can?
Opened bonnet and OH FCK! Missing oil cap and ruined oil stains all over the once tidy bay :eek::oops: immediately shut off engine incase it was dry.
So I’ve been blasting around Blyton with no oil cap eh. How the heck did that come off and where is it? Then realised I musta forgotton to tighten the cap after topping up after the sighting lap Doh! Such a dumb mistake.
I felt like James May in that topgear episode with the cheap porsche challenge yrs ago where he had carefully restored the 944 tidy engine bay for the porsche adjudicators, stiggy blasted it round the track only to find this mess afterwards.
Checked oil level and thank god it’s still bout 60% so I’ve been lucky (saved by the annoying foot pump) that I didn’t run out of oil and ruined the engine.
Urm so I can’t find the cap anywhere, highly unlikely to find on track, Alex doesn’t have a spare and I can’t run without it…call Andy, but he’s already left on the way to the track.
He arrived, we sorted Alexs car out, me n andy went out to afew scrappys to grab an oil cap, musta been the fastest time I’ve been straight in/out of one, andy almost got carried away from looking at all the potential goldmine lol. Refitted oil cap and ready to go.
12:17 -------------------------------------------------------------------------------------
Before
Setup:
Dampers: 15/30 F/R
Weight: 50% fuel, me & andy​
Misc changes:
  • Fit new missing oil cap
During:
Track feedback:
  • high grip
  • high traction
  • high speed steady understeer
  • high speed rapid directional change creates oversteer to aid turn-in
  • braking with whole foot over pedal improves braking force
  • not enough servo assistance
  • long brake travel
  • moved to 50/50 brake bias
  • ½ throttle steady turns would understeer
  • high braking force
  • occasional rear tyre skid @50/50 trail heavy braking
  • legs need more seat support
  • seat cusion near RH thigh collapsed to bare metal frame & hurting my hips
Track Times:
1.26
1.22
1.23 traffic
1.31 traffic
1.26
13:40 -------------------------------------------------------------------------------------
After lunch, went out with dad.
Before:
Setup:
Dampers: 15/30 F/R
Weight: 25% fuel, me & dad​
Misc changes:
  • Loosened throttle cable to lower position & avoid pushing both brake & throttle pedals during heel toeing.
During:
Track feedback:
  • slightly improved brake/throttle position
  • good high speed left turn grip
  • moderate right turn grip
  • better braking entry
  • at high speed Port Froid = keep 100% WOT to lock front LSD, quickly turn steering 1m before apex to shift & settle weight transfer, stiff rear dampers will induce oversteer to help change direction rapidly when we reach apex
  • almost out of fuel
Track Times:
1.32 traffic
1.36 traffic
1.25 traffic
1.22
1.22
1.35 traffic
1.30 traffic
14:20 -------------------------------------------------------------------------------------
The red saxo driver I was keeping up with was surprised & impressed.
Mentioned bout my understeer, found that they ran same tyres but at a lower 2bars whereas I was running 2.5/2.7bar and trying to keep the wear of both wheels within the thread patch and causing understeer.
Since the front needs more grip, I began to lower it to 2.2/2.7bar f/r and see if it improves mid-corner
Before:
Setup:
Dampers: 15/30 F/R
Tyres: 595RSR 2.2/2.7bar F/R
Weight: 10% fuel, me & sam​
Misc changes:
  • Saxo driver with same tyre advised lower tyre pressure towards 2bar.
  • Reduced fronts to 2.2bar to help understeer
During:
Track feedback:
  • improved front turn in
  • double pumping brakes has no effect so pedal is still within MC travel
  • brake pedal too low, also pushing throttle and not slowing down enough
  • need refuel
Track Times:
1.24 traffic
Forgotten to refuel with 5L reserve
15:10 -------------------------------------------------------------------------------------
Before:
Setup:
Dampers: 15/30 F/R
Weight: 25% fuel, me & sam​
Misc changes:
  • Refuelled with 5L reserve
During:
Track feedback:
  • found that 100% power before mid-corner locks the LSD and pulls the front end towards apex earlier
  • rapid steering changes before the apex at high speed induces a faster moment of inertia and helps turn-in
  • Alexs lighter K11 can brake later
  • Trail braking 1st corner understeers
  • Trail braking last corner oversteers with 50/50 bias
  • During high speed RH trail braking when it oversteers, do not excessively countersteer left towards grass AND downshift badly which relocks the LSD to unsettle the car with the new steering angle and results in sudden LH snap onto grass. Further braking whilst skidding left just makes it worse. Instead, apply WOT or both braking & WOT to vector thrust the vehicles direction and point steering RH towards apex.
  • 100% braking in straights, ease trail braking during entry then WOT before apex.
  • Understeers once tyres working harder and hot pressure increased above 2.3/2.9bar
Track Times:
1.23 following alex
1.27 following alex
traffic & skidding off
1.26 traffic
1.24 traffic
1.22
0-60 approx 9s
Quickly out of fuel, went out with Alex to refuel at services
16:30 -------------------------------------------------------------------------------------
Refuelled and took Alex around. Lowered the front down to 2bar to see if it reduces understeer more.
Before:
Setup:
Dampers: 15/30 F/R
Tyres: 595RSR 2.1/2.7bar F/R
Weight: 60% fuel, me & alex
Misc changes:
  • Refuelled 15L
  • Further reduced front pressures
During:
Track feedback:
  • Good high speed turn-in & neutral mid-corner balance & rapid directional change
  • Aggressive high-angle fast steering during WOT through Port Froid helps speed up turn-in directional changes
  • Either brake fade or brake pedal too low & touching throttle so overshot The Wiggler
Track Times:
1.24
1.26 traffic
1.36 traffic
1.22
1.22
16:50 -------------------------------------------------------------------------------------
With the setup mostly dialed in, lets see how it handles with no passenger weight and light fuel load.
Before:
Setup:
Dampers: 15/30 F/R
Weight: 30% fuel, driver only​
During:
Track feedback:
  • More rapid acceleration & deceleration from reduced weight
  • 80kg driver weight on RH made it understeer during high speed slow steering right-left s-bend
  • very aggressive fast steering rate on high speed right-left s-bend makes it oversteer more
  • low speed turn-in & mid-corner is sharper
  • left foot braking during WOT when exiting left bend not very useful cos it won’t break rear grip to induce oversteer when most of the weight is transferred backwards under high acceleration pushing on the rear tyres and rear discs are not powerful enough.
Track Times:
1.21
1.20
1.27 traffic
1.40 traffic
0-60 approx 9s
After:
Tyres: 595RSR
2.1/2.7bar F/R Hot
2.0/2.6bar F/R Cold
Laptimes: Outer Circuit
10:00, 595RSR 2.5/2.7bar, passenger, 60% fuel =
1:27
12:17, 595RSR 2.5/2.7bar, passenger, 50% fuel =
1:26
1:22
1:26
13:40, 595RSR 2.5/2.7bar, passenger, 25% fuel =
1:22
1:22
15:10, 595RSR 2.2/2.7bar, passenger, 25% fuel =
1:22
16:30, 595RSR 2.1/2.7bar, passenger, 60% fuel =
1:24
1:22
1:22
16:50, 595RSR 2.1/2.7bar, driver only, 30% fuel =
1:21
1:20
my laptimes have been pretty consistant and progressively improved as I got more confident with the car & track, as fuel got lighter and especially with no passenger weight.
Oh another thing I found at the services on the way home whilst checking oil, was the missing oil cap on top of the turbo compressor housing :rolleyes:
Checked the new spark plugs after first day at blyton, look nice n clean.
Changed to 15w40 oil & filter to see if it stops morning smoke, nope.
Assessing the 595RSR, outer loaded shoulders getting worn the most.
Front right
and there's this deep gash in it from somewhere
Rear right
Rear left
Front left
2015-04-11 Blyton Park
arrived at Blyton in gusty cold rain downpour that’ll clear at lunchtime.
It’s a nice oppurtunity to tune for the wet as well as dry conditions.
Instead of getting my hands wet n freezing changing from t1r to 595rsr n back again later, I decided to keep the t1r on, tune it in the damp wet (since I’ll be running the deeper toyos if it rains in germany and federals if dry) then change to 595rsr once it’s dry.
9:04 Outer Circuit Sight Lap -----------------------------------------------------------------
Rather than run ½ tank and fill up several times, decided to brim up full for less hassle (later found she drinks faster than usual :p)
Before:
Setup:
Dampers: 15/30 F/R
Tyres: T1R 3/3bar F/R
Weight: 100% fuel, me & dad
09:40 -------------------------------------------------------------------------------------
Started off with my normal pressures and 50/50 bias with passenger & full tank n see if it understeers or oversteers.
Before:
Setup:
Dampers: 15/30 F/R
Weight: 100% fuel, me & dad​
Misc changes:
  • Brake bias 50/50 F/R
During:
Track Condition: damp & cold windy
Track feedback:
  • Rears locking at 50/50 bias
  • Trying to WOT & lock the LSD mid-corner with T1R in damp makes it power understeer
  • Dial more front bias, less rear locking
  • Can only slowly feed throttle through corner without power understeer
  • Trail braking = understeer
  • Not enough confidence in low front grip to go WOT through high speed Port Froids
Track Times:
1.42 traffic
1.34
1.32
1.30
1.30
1.30
1.36 traffic
1.31
1.41 traffic
After:
Tyres: T1R 3.3/3.25bar F/R Hot
Ran same setup with only driver weight, improved turning & braking but brakes began to whirr and foot camera fell off.
Before:
Setup:
Dampers: 15/30 F/R
Weight: 90% fuel, driver only​
During:
Track feedback:
  • Groove disc very slightly whirring
  • Brake pedal too low
  • High speed s-bend better turn-in
  • Pedal camera fell out
Track Times:
1.32 traffic
0-60 approx 11s
10:30 -------------------------------------------------------------------------------------
Taped the foot cam back on and lowered front pressure to help understeer. Track was drying so the tyres improve.
Before:
Setup:
Dampers: 15/30 F/R
Tyres: T1R 2.90/3bar F/R
Weight: 75% fuel, driver only​
Misc changes:
  • Secured pedal cam
During:
Track Condition: intermediate drying & cold windy
Track feedback:
  • High speed Port Froids with WOT = understeer
  • Good braking, no rear lockup with 50/50 bias
  • WOT low speed exit good grip
Track Times:
1.29 traffic
1.41 traffic
1.25
1.24
1.26 traffic
0-60 approx 11s
After:
Tyres: T1R 3.1/3.1bar F/R Hot
10:45 -------------------------------------------------------------------------------------
Sun was now drying the track and getting slightly better but these weak T1R are a lot more unstable than the 595RSR and just understeers.
Before:
Setup:
Dampers: 15/30 F/R
Weight: 50% fuel, driver only​
During:
Track Condition: dry & warm
Track feedback:
  • WOT exit turns good
  • High speed understeer
  • Good brake force
  • No rear lockup at 50/50 bias
Track Times:
1.23
1.26 traffic
1.24
1.27 traffic
0-60 approx 9s
11:50 -------------------------------------------------------------------------------------
With a dry track, time to change to the sticky 595RSR. Left cold pressures same as last time. Feels so much better n stable
Before:
Setup:
Dampers: 15/30 F/R
Tyres: 595RSR 1.9/2.4bar F/R Cold
During:
Track feedback:
  • Grooved disc whirr becoming noticable
  • Slight high speed Port Froids understeer
  • Good brake force
  • Occasional slight rear lockup at 50/50 bias
Track Times:
1.30
1.25
1.27 traffic
1.24
1.22
1.21
1.21
09:40, T1R 3/3bar, passenger, 100% fuel =
1.34
1.32
1.30
1.30
1.30
1.31
10:30, T1R 2.9/3.0bar, driver, 75% fuel =
1.25
1.24
10:45 T1R 2.9/3.0bar, driver, 50% fuel =
1.23
1.24
11:50, 595RSR 2.1/2.7bar, passenger, 25% fuel =
1:30
1.25
1.24
1.22
1.21
1.21
once again consistant improvements as the track dries and especially changing to a gripper 595rsr, I reached the same 1:21 best time as last time, even with a passenger onboard.
13:33 Eastern Circuit Sight Lap -------------------------------------------------------------
Refuelled during lunch, found she actually does 16mpg on track at full chat :eek:
We would now change over to the Eastern circuit layout so had to go for a sighting lap
Before:
Setup:
Dampers: 15/30 F/R
Tyres: 595RSR 2.0/2.7bar F/R
Weight: 100% fuel, driver only​
During:
Track feedback:
  • Notice louder brake disc whirring plus slight whirr during right turns
14:30 -------------------------------------------------------------------------------------
The louder whirring noise was concerning, checked the disc and ABS ring n wheel bearing but they’re all fine? Adjusted pressures to 2.0/2.7bar f/r and found the brake pedal locknut was loose causing the pedal to drop abit. Lifted the brakes back up and loosened the throttle cable to drop the pedal lower.
Before:
Setup:
Dampers: 15/30 F/R
Weight: 100% fuel, me & andy​
Misc changes:
  • Bias 50/50
  • Readjusted loose brake pedal shaft
  • Loosen & lowered throttle pedal
  • Check if wheel bearing or ABS ring was whirring, all ok
During:
Track feedback:
  • Brakes bite much higher, can apply more pressure without touching throttle
  • Brake pedal briefly became very high, then return to normal height
  • Brake probably faded later on?
Track Times:
1.33
1.28
1.42 traffic
1.32 traffic
1.30 traffic
1.28 traffic
1.31 traffic
1.27
1.28
1.29 traffic
1.26
I luv this eastern circuit layout, such a thrilling challenge.
15:30 -------------------------------------------------------------------------------------
Brakes were too high so lowered it abit and went out with colin.
Before:
Setup:
Dampers: 15/30 F/R
Tyres: 595RSR 2.0/2.6bar F/R
Weight: 75% fuel, me & colin​
Misc changes:
  • brake pedal slightly lower
During:
Track feedback:
  • Brake pedal slightly too low
  • Good brake force
  • No rear lockup
  • Good high speed direction change
  • Last corner front tyres always squeals
  • Bumpy curva grande always squealing on braking limit
  • Once tyre loses traction, locks & squeals after hitting bump on curva grand, it understeers if still trail braking. Must reapply brake & steering to regain traction
Track Times:
1.47 traffic
1.28 traffic
1.25
1.28 traffic
1.26
1.29 traffic
1.29 traffic
1.26
After:
Tyres: 595RSR 2.3/2.8bar F/R Hot
Tyre pressures is a continuous chain reaction.
Correct the pressure, they work better & harder whilst within designed spec, gets hotter, pressure builds till handling degrades, recheck pressure, rinse & repeat.
15:50 -------------------------------------------------------------------------------------
Moved brakes abit higher to what I like. Went out with lower fuel and no passenger, it felt good n confident. The worn seat was abit painful but was exciting keeping up with this fire spitting black mx5 with a honda engine.
Before:
Setup:
Dampers: 15/30 F/R
Misc changes:
  • brake pedal slightly higher
During:
Track feedback:
  • Grooved disc rumble noise from totally worn inner LH pad
  • Good brake pedal firmness point
  • Slightly squishy brake pedal
Track Times:
black flag cos of bonnet
1.22
1.26 following mx5 honda
1.24 following mx5 honda
0-60 approx 11s
Laptimes: Eastern Circuit
14:30, 595RSR 2.0/2.7bar, passenger, 100% fuel =
1:33
1.28
1.27
1.28
1.26
15:30, 595RSR 2.0/2.6bar, passenger, 75% fuel =
1:25
1.26
1.26
15:50, 595RSR 2.0/2.7bar, driver, 50% fuel =
1:22
1.26
1.24
1.24
Getting consistantly faster as I learnt the layout and fuel got lighter. Reached peak best at 1:22 with no passenger but got held up behind the black honda engined mx5.
It’s been a successful few test days at blyton.
Driving back home with cold brakes, the grooved discs were now really really whirring loudly and brakes don’t bite as hard.
Later found at home that the inner LH pad has actually worn down to bare metal to metal! Woops
These grooved discs are a cheese pad grater, need to change over back to smooth oem discs
That gash in the last picture looks like the tire delamination that a lot of the 595rsrs suffer from
Sent from my SM-G900F using Tapatalk
no idea, just a clean straight tear across the face, pot hole? or when I skidded off into the gravel/tarmac at the last bend with sam? it's the highly loaded front RH tyre on an anti-clockwise track.
dad took some photos on the first blyton trackday and its interesting looking at the weight transfer
launching out the pits, how the rear squats down
corner entry
mid corner
corner exit under WOT, the RH fully loaded and most of the weight going on the rear right wheel pushing it into the arch and the rear left wheel is made to mimic the motion by the multilink beam axle and stiff swaybar to resist roll upto a point till it lifts up. most drivers commenting how much my inner rear wheel always pops up on every corner :D
I like these motion blur shots he took
Not sure what causes it to be honest. CoV on AOC had a similar issue running the same tires daily. It seems a very common issue with them. A quick Google would probably give more information :)
Happened on the Avon CR500's I was running a few events a go, have just carried on and they've been fine :) it is odd though
Haha, I was laughing over my morning cuppa at you chucking it into that high speed left hander with the tyres squeeling Paul.
it's the 1st I've seen this before, I'll see how it goes over next few tracks. not read bout anyone with the same cracks having a blowout on track.
amazing skill doing that^
I want to swap him out for that bird with 2 ear studs in the F1 :) you get me?
u mean when I skidded off or that awsome fast right-left Port Froids? twas loads fun when it works out well. luv how u just have to force her into the corner (urrm that sounded really wrong haha) and believe she'll make it stick.
lewis?
Two great reports there :)
Couple of things, where do you mount your suspension view camera? And the shoes you are wearing are quite wide so that won't help the catching the throttle / brake pedal issue. Proper driving boots are quite narrow.
Also you are FAR less aggressive behind the wheel than I am....!
The smoother the better!
Less aggressive steering input allows for weight to move around, basically giving better traction :)
thanks matt n alex
some behind the scenes shots
tis just cos I wear the same uniform all day, I'm comfy in it and cos I used the car daily to/from work, I learnt heel & toe in my work clothes/shoes n adapted to em but they can only do so much and cos of the long brake pedal issue, it's beginning to make me mash both pedals. tis like heel toeing in wide trainers :p
so yeah agree narrow driving footwear would be better once I resolve this pedal height travel issue. ohh actually I had some slim narrow smooth-sole running trainers that I once liked driving in but haven't worn in yrs, give em a try soon.
hehe the smooth driving style is just what I'm used to (prob learnt from racing games to get fastest times) that helps provide a consistant and stable performance. taught to be smooth, slow in fast out, not overwhelm the tyre with limited capacity. I used to find that sharp agressive steering on cold street tyres would just upset the balance, front understeers and shreds tyres.
but now with sticky hot semi's (no pun intended ppl lol) balanced suspension, locking LSD and high torque, it's a totally different dynamic behaviour.
so the past two trackdays have been two things:
discover kasandra's sporty side, taking her out for a run/sprint so-to-speak, her personality under load, her strengths weaknesses, what setup she likes or hates.
second is redeveloping my own skills on how I should drive her in any situation/scenario to achieve the best out of her and stay outa trouble.
to discover with her working LSD, stiffer rear end and sticky solid shoes that likes to be forced & pushed around corners was a nice surprise to find over the past two days. she's one naughty feisty girl eh ;) winkwink
is it a worry that I have so many sexual or relationship innuendos with kasandra? :D:p or maybe I look into it too much. ehh moving on..
oh talking of steering smoothness, that highspeed Port Froids I like where I just flick her the other way I do find that the rate of steering change, how aggressive I force her, changing her moment of inertia was a very useful technique to affect her handling.
if I go too smooth, the tyres already reached a limit and generally understeers.
too aggressively fast, the stiff rear dampers lift the inside wheel to lose grip induce oversteer and the rapid moment of inertia makes the car spin too fast into apex and oversteers.
there's a fine balance to get this rate of inertia just right to make her turn and bite the road.
for Andy, here's the pics of the K11 strut towers
underneath the front stud
under the rear stud
there's little room for a disc shaped topplate
to fit a disc plate underneath but within the rounded edges, it'd be 101mm dia and the stud bolts would be at the very ends to secure it, getting the gap between the studs is important to keep it securely locked.
changed engine & LSD oil
usual bits on the gearbox plug
andy sending me a pair of normal smooth gtir discs. another ££ two sets of pads for next few tracks & germany, just hope they last longer on standard discs.
lets sort this throttle pedal out. trying the stack some bits over the original bumpstop is fiddly and rough, instead I need it adjustable
removed the cable
abit of the rear outer cable snapped but that's ok and no issue
cut off this useless bit
also cut off this useless rubber cusion for more precise feel and also allows me to drop the pedal even further without affecting the cable
tapped & fitted an M12 stud
now I'm able to fully adjust the brake vs throttle pedal height till it's perfect and I don't mash both pedals.
need to wrap some cusion on the stud cos metal/metal makes a loud tapping noise when I release the pedal
Andy! new episode of project binky :eek::):D
once again seriously impressed with the ingenuity, the slider bumpstop, stamped scuttle vents, rad/IC mount,
@16:55 the motorised bonnet I was :eek: then his grin @17:00 was lmao :D
I could do with em s2000 seats.
disassembling the rear load sensing brake valve
the arm has a balance rocker to keep even load between the two plungers
remove dust cover
these unbolt
the sprung loaded plungers
one-way valve
and the internal plumbing
while I'm here & before I throw this ABS modulator out, once again curious to see what's inside :cool:
disconnect electrics
the pump unit is isolated from the metal frame via rubber pegs
removed
unbolt & remove the cover
interesting, these are the solenoid valves for each port
wiring comes through to the solenoids here
unbolt the motor
and pops out
so here's the elliptical cam that drives the pump
inside the housing are the pumping pistons
this bit unscrews
this is as far as I'll take it and has been interesting
Oh I know :D
I was sat waiting for the upload from 7:30. Watched episode 8 as a reminder.
Posted to Richard saying I'd watched 8 and ready for 9.. 4 minutes later he'd uploaded it. So the world came to a temporary pause while it was watched.
Flip front goes up...
ok dug abit deeper into the ABS unit
removed this nut
to reveal this filter before the pump
desoldered the circuit
wondering how to remove these solenoids
found the outer locking collar prys off
and valve pops out, looks very similar to an injector
eventually got this inlet pistons out
well that's enough of the unit.
chuck in bin
have to get on with welding the cracked manifold
