Good work so far, oversills are a much maligned repair amongst mini enthusiasts, done when minis were worth nothing to get them through MOT. The outer sills should be spot welded on the floor panel and on the outer seam, the ends were the hard bit to get out cleanly on my mini as they were bronzed in.I've yet to do the lower sills too which seems more difficult
from the recent classic car meet I met Gee who needed help with welding a rust hole on his mini. initially thinking it was a small hole to patch up and quoted £40 but as usual this turns into a bigger job
at first it looks abit meh with the rust spreading to the lower sill
but some prodding and wirebrush reveals a horror of rotten sills and mass of bodyfiller ?
christ! the insides are just rust and dodgy filler, plus it's been fitted with 'over-sills' which don't feature the original drain ports and simpy traps more water & rust ?
chopped the pourous rusty parts out and vacuumed all the debris
this tigersealed gaping hole might be where water could be leaking in
grinded the old spot welded strip out
this cheap copy pattern sill wasn't a precise good fit. I trimmed the front part to match
but just look at this mess
it doesn't match the door line curve, different spacing and doesn't reach the end far enough
so I had to split it into sections to line it up and then fill in the gaps
drilling the plug weld holes is a chore
tack welded in place
with the wind picking up, welding it outside with an inconsistant unpredictable welder is frustrating ?
grinded the welds flat
View attachment 71726View attachment 71727View attachment 71728View attachment 71729
that was definately a pain to do and worth more than £40 work. I've yet to do the lower sills too which seems more difficult
I think you should be charging £40 per hour not job! Many years ago the MOT station I use where charging £10 per inch of weld and apparently that was cheap ?. Luckily I've always done my own repair/ restoration
I've lost count of how many mini door step and sill jobs I've done now and these days I don't bother repairing, I just buy a complete inner and outer sill repair panel that's already spotted together and Replace the lot in one go.
What welder are you using for it to be inconsistent?
Just bite the bullet and buy a mini. You know you want too
Just bite the bullet and buy a mini. You know you want too ?
Quote: "You know you want too" do what, in a Mini?
Enjoy.
Looks good and fits well Paul. My only thought is how resilient is the material and will it keep it's shape for any length of time? I have made firmer bushes for suspension joints for my MG Midget in the past to replace moulded hard rubber ones but I machined them from black Nylatron which I know has very good wear properties and has a high resistance to impact and oil contamination..............3D print solid steering rack bushings
The steering rack has been squeaking a lot and felt slightly sluggish.
This was partially caused by cutting the 'square' half of the rubber bush so that I could fit a machined half-circle bushing as an early attempt to reduce play. but what it actually did was allow the mounting bracket to pivot from the front side and the very loose fitting rubber mount at the back allowed the bracket & rack to 'swing' sideways resulting in sloppy response.
to unbolt the rack, first I had to detach the steering column UJ off the rack. decided to unbolt it from within the footwell which was slightly easier than trying to remove the cover from the tight engine bay
so here's the sloppy rubber rack mount, notice the huge gap between the rubber sides and the mounting bracket
View attachment 72400View attachment 72401
modelled a tighter fitting new bush
View attachment 72395View attachment 72396View attachment 72397
3D printed over 6hrs
View attachment 72402View attachment 72403View attachment 72404
Snug install
went for a test drive and ooh the steering finally feels very sharp & responsive?
if I ever see a row of those at a car show, they'll literally be like peas in a pod![]()
Have you driven an early one? My first car was a 1960 Mini van, (some 53 years agoI don’t understand the attraction of the early Mk1 Mini, a now 60 year old design that is not safe or suitable as a daily runabout in congested modern traffic levels?![]()
Very good choice.
I have the same machine & helmet. You will probably use that whole bottle just practicing and trust me it's all practice practice practice when it comes to learning TIG the 4hrs training is a nice option.
Personally I don't have an issue with the larger 26 torch but everything is personal choice and comfort is probably one of the most important things
I'm a bit odd and find aluminium easier than steel when it comes to tig.
Good luck and keep practicing ?
A few things no forgot to say...
Its worth checking out welding tips and tricks on YouTube. His videos are a great learning aid.
Clean your metal and when you think it's clean, clean it some more. ( Including the earth point)
Get a dedicated machine/wheel for grinding tungsten. Trust me you will be dipping your tip more than a jiggalo. As soon as you contaminate the tungsten clean it, dont carry on trying to lay a bead.
I found a "mini" bench grinder in Aldi (£20-ish) which is used solely for tungsten.
Tungsten choice can make a difference. I only use 2% lathinated now as it does everything well and I don't have to worry about changing it.
