CMF_GTRHOLIC
» CMF MemberHi all, dont know if this will help anyone, but i just bought some Japanese performance parts. I thought i might list some part numbers for japanese parts for reference if anyone were to be looking for them.
Here are the nismo items i ordered.
NISMO STEERING GEAR MOUNT BUSH
RIGHT SIDE 48376-rs220
LEFT SIDE 48377-rs230
(PLEASE NOTE WILL NOT SUIT CARS 92/1~93/11 WITHOUT POWER STEERING AND WILL NOT SUIT 99/1~ AUTOMATIC CARS WITH POWER STEERING)
NISMO FRONT ENGINE MOUNT 11211-RS260 (NEED 2)
NISMO REAR ENGINE MOUNT 11321-RS260
NISMO FRONT BUFFER ROD 11350-RS260
NISMO TRANSVERSE LINK BUSH REAR 54476-RS260 (NEED 2)
NISMO TRANSVERSE LINK BUSH FRONT 54535-RS251 (NEED 2)
NISMO UPPER LINK BUSH AXLE 55046-RS260 (NEED 2)
NISMO UPPER LINK BUSH BODY 55046-RS261 (NEED 2)
NISMO LOWER LINK BUSH AXLE 55045-RS260 (NEED 2)
NISMO LOWER LINK BUSH BODY 55045-RS261 (NEED 2)
NISMO PANHARD ROD BUSH AXLE 55135-RS260
NISMO PANHARD ROD BUSH BODY 55136-RS260
NISMO FRONT LOWER ARM BAR 54110-RR260
NISMO PANHARD ROD (ROSE JOINT) 55130-RR260
NISMO ADJUSTABLE PANHARD ROD 55130-RS261
NISMO S TUNE SUSPENSION KIT 5300S-RSK10
NISMO FRONT STABILISER BAR 54610-RS260
NISMO REAR STABILISER BAR 56220-RS260
NISMO MASTER CYLINDER STOPPER 46000-RS260
NISMO S TUNE BRAKE PADS ~97/5 41060-RN16A
97/5~99/11 41060-RN18J
99/11~ 41060-RN22A
NISMO MECHANICAL LSD 1.5WAY ~99/11 CG13DE 38420-RS250 FINAL RATIO 4.353
NISMO CLUTCH DISK 30100-RS261
NISMO CLUTCH COVER 30210-RS261
NISMO RADIATOR CAP 21430-RS012
NISMO METAL HEAD GASKET 0.6MM 11044-RR262
NISMO METAL HEAD GASKET 0.5MM 11044-RR263
TOMEI PROCAM CAMSHAFTS
INTAKE 256DEG 8.35MM LIFT 144F256083
EXHAUST 256DEG 8.35MM LIFT 144G256083
0.7MM METAL HEAD GASKET GROMMET TYPE 1346727071
THERES A BIT MORE. WILL LIST THEM SOON
HOPE THIS IS HELPFUL FOR THOSE WISHING TO ORDER JAPANESE PARTS FOR THEIR CAR.
99/11~ 41060-RN22A
