B Blue Dragon Guest Sep 1, 2005 #1 How do you remove overspray on plastic doorcards? Anyone got any tips?
5 59 bhp is more than enough Deactivated Account Sep 1, 2005 #2 usually some white spirit soes the trick
Ed Fusion Motorsport MSC Founder Official MSC Trader Sep 1, 2005 #3 celulose thinners is a better idea, warning though, anything like this may damage plastic.
OP OP B Blue Dragon Guest Sep 3, 2005 #4 i tried white spirit but that did nothing, im a bit worried about the thinners, but i'll give it a spot test before i do any large area! Cheers guys
Retepetsir King of Subsonic Sep 3, 2005 #5 Ed said: celulose thinners is a better idea, warning though, anything like this may damage plastic. Click to expand... It depends on the type of plastic........as I know some just melt away....!
Ed Fusion Motorsport MSC Founder Official MSC Trader Sep 3, 2005 #6 exactly - hence why i said this! White spirit btw has no effect on car paints.
R05_Micra Ex. Club Member Sep 3, 2005 #7 nitromorse bit water in. i suppose it shud be ok if you 1) wipe over nitromorse 2) clean with white spirits on a rag. will remove and do no damage.
OP OP B Blue Dragon Guest Sep 3, 2005 #8 The paintstripper stuff you use on wood? Its some strong stuff! Are you sure it won't cause any damage?
O ohc_turbo Guest Sep 3, 2005 #9 when i tint lights i use nail varnish remover to get the paint off, cant do no harm borowing some unless you have some yourself
Ed Fusion Motorsport MSC Founder Official MSC Trader Sep 4, 2005 #11 Cellulose thinner!!!!!!!!!!!!! It will remove it, try it on a hidden bit of plastic first.
