One of my fave K11 :)
CMF_jdc5r
1/9 Tsukuba circuit course 1000 41.782
1/9 Tsukuba circuit course 2000 1.06.490
3/12 Fuji speedway short course 37.238 * first travelling
* A-1 - B-3 - The C-2 route (when engine out of order the time 6 - 8000rpm or more it does not turn)
Specification 2006
Engine type: CG13DE
繧ッ繝ュ繝「繝ェ 蜑・it comes out, the crankshaft (detailed secret)
繧ッ繝ュ繝「繝ェ H section 繧ウ繝ウ繝ュ繝・ャ繝・(detailed secret)
Piston for motorcycle (for something secret)
Big valve (detailed secret)
IN/EX 80 degree camshaft (lift quantitative secret)
In addition, special processing
Installed capacity 180ps/8500rpm (at BOSCH chassis dynamo)
Inhalation and exhalation of air
4 connected slots for NISMO make N2 (as for control MoTeC M4)
Custom-made stainless steel make exhaust manifold
Custom-made titanium make center pipe & muffler
Drive
The 繧ッ繝ュ繝「繝ェ lightweight flywheel for N2
Strengthening clutch cover & disk
NISMO 1.5WAY LSD
5 fast directly connected missions
Underside
RG make height adjustment system (as for spring Swift make F10Kg/R10Kg)
Brake
Front the caliper for S13 NA - + Delphi ZR
As for rotor the NISSAN genuine products for MA09ERT
The rear transplants from the model for the ABS attaching 4 wheel disk
Equipment
繝代・繧ォ繝ォ make LAPCOM VX-2000
繧ッ繝ュ繝「繝ェ make 7 point type roll gauges
ATL make safe fuel tank (capacity 8 gallons /30 liters)
Tire & wheel
F YOKOHAMA A048 185/55/14 TE37 7J-14
R YOKOHAMA A048 185/55/14 TE37 6.5J-14
Wrapping
The kit installing 2 name riding in a car for NISMO genuine N2
