CMF_turbo march-rolling shell
» CMF Memberthat's awesome..you need some defi's filling the spot were the climate controls are but!
Tony WROTE:
"Hey turbo,why don't you put together a basic turbo kit (extra injecter+piggback computer) that you can sell in parts or stages. So people with not alot of dough can get into the turbo game,you could sell them worldwide. And i no you could knock them up easy?<BR><BR>Which reminds me do you want fit/install my turbo kit?? Buddy<BR><BR>Also got the car back to from suspension shop and had a bent control arm from previuos accindent/owner,now with camber bolts and all balanced and aligned its handling pretty good,off course whiteline could not supply my antilift kit in time,typical
smidge WROTE:
"you can do everything yourself on a more expensive car too, its just more scary when you stuff it up, or when something spits a gearbox etc<BR><BR>they won't be quite as cheap when parts start getting rare, but still an awesome little car to buy and own,<BR><BR>don't listen to what turbo tells you, its okay to want a car you can mod cheaply
smidge WROTE:
"i was just stirring the pot.... <BR><BR>looking forward to the blog for your N/A to beat all N/A's...
sodaniel WROTE:
"UPDATE
the n/a march has now been dynoed + tuned
(mod list as per first post)
Dropped the car off yesterday morning to Indy @ IS Motor Racing (rockdale) and the car had a full service + Tomei poncams installed + Dyno tune
Results below:
<img src="http://www.soasiandvd.com.au/files/dyno.jpg">
64.5kw @ 6500rpm (at the wheel figure) equivalent to roughly 81kw or 108hp @ engine (calculating at 20% drivetrain loss)
Stock = 55kw or 74hp at engine... which means an increase of roughly 46% from standard.
What can I say, I'm extremely happy with the figures (although not that high, this car was only 55kw @ flywheel standard right???). The dyno graph expresses how the car drives at the moment... it just pulls and pulls and pulls, no flat spots and very linear power delivery. My AFR is also on the spot too, without having to tinker around with fuel pressures.
Basically with Intake, 4-2-1 header, hi flow cat, 2 mandrel bent system, GA15 throttle body, GA15 injectors, cams, light flywheel, light wheels, the car was able to do 60kw @ wheel. But from additional tuning of the piggyback, Indy could manage to squeeze another 4.5kws...
The car idles at standard levels now and sounds SO LUMPY (it's actually very cool), and the mid range is so much meatier now. With such a light chassis, I'm really keen to take it back out to wakefield park now to see what lap times I can get (best was 1:19 by my brother - back when the micra had NO power mods).
Extremely happy with the tune, I recommend IS Motor Racing for anyone in Sydney looking to do more work to their cars, but as for me the search for power will come to a temporary halt for the moment as chasing more ponies is going to cost mega-bucks, which I'm not prepared to dump in.
Would I recommend going this way?? Well if you are chasing HP, seriously do it the turbo route... But I am an N/A maniac and love the sound.
To give you a rough indication of what cost is involved in chasing NA power...
Complete exhaust - $1000
Intake set up - $100
GA15 throttle body - $175
GA15 injectors - $150
Tomei cams - $600
Apexi AFC Neo (piggyback ecu) - $320
total = $2345
not including labour... all up my labour was around $400
So seriously give it some thought before you go down there!
cheers!
Daniel
