Under the dizzy, a pita to get toWhere is the engine temp sensor on the cg13?![]()
Will I have to remove the dizzy?if yours drops back down when you whack the dash pod, then its just a bad connection mate, and the 1 wire sensor under the dizzy![]()
FTW ?????? See this on here all the time. Meaning ????? Checked the urban dictionary, it seems to mean a lot of things.Frank and ghetto mods FTW!
For the winFTW ?????? See this on here all the time. Meaning ?????
Yeah mines started doing the same thing.my gauge used to randomly go to max now and then (and a whack on the side would drop it back down)
so i prized the tabs on the offside connector, ok so far![]()
I've 2 brand new sensors, unused if you're interested.It was sitting higher than it should this morning on the drive home.
I dont quite no what to do about it.
Ill give it a service and clean up temp sensor see where we go from there...
Rad cap looks fine but I will replace asap.Dodgy rad cap?like on k10'nts
I work nights buddy so dont really drive during the day, its alot cooler at night.Has it got anything to do with this immense heat ?
I know... after oil change temp needle still climbs when im stationary and if I stay at the same speed for to long... I just cant dig any more info out of my old mechanics college/apprenticeship part of mindBummer![]()
Im sure it will say in the haynes manual mate thanks thojust that temp sensor eh, here,s the ohms for the 2 wire one, not sure what the 1 wire one should read tho
Changed oil and filter didnt have time to look at the temp sensor due to a monsoon in norwich
Will check as soon as I get my bible back... aka haynes manual.
@clodo gimmie back my book!!!! Im going to start charging you for borrowing things lol
Yup and yup... regardless of speed.So your temp gauge climbs when stationary... and when the the flow is constant for too long... Regardless of speed?
You haven't got any leaks have you?
Try putting your heater on... feel the temp of it... and see if you notice a change in temp when the gauge indicates one
Do it its hard back lolShhhh you or I'll run your Haynes manual overI might start charging for my company... Friendship fees
anywho I need it to fix Mildred and Millie
X
Erm lost me there chap? Heater matrix?Leaking matrix?
Doesn't sound like its getting round :/
If your started climbing... and you slowed down.. the gauge go down too?
Ffs... is nothing ever simple ill have a look and see if I can smell feel or trace a loss of coolant in the car.Its a dashboard out job.
Even on a k10 a couple of hours work
You'd know if it was leaking. Heater cold. Rising engine temp (different to your situation) it'd smell funny in the car. Not to mention the wet carpet
Just seems your coolant is getting lost somewhere :/
Maybe once hot it goes into the expansion tank but doesn't return once cooler?
Plenty of engines my way chap im due a bigger one anyways next year for me is all about turbos I thinkIf u get stuck or engine shagged I might have 1 for sale soonish its a 1.3 super sport serviced alot 89k miles and will continue going up as daily runner till missis car back on road then hopefully engine swap will start
Cap off run engine till hot but I will put the fan on full when I do today.How do you bleed your rad?
I will check frank and see where we go from there.
Not that im aware of mate.Do you not have a bleed screw in one of your matrix pipes?
Worth getting one if you can and mount it furthest from radNot that im aware of mate.
Will have a look into this mate but cant see it making a difference as the k11 is not really a pressurised system hence needing to run with cap off rad.Worth getting one if you can and mount it furthest from rad
I know... and you'll hate me.. saxo's and 106's have a bleed screw in their matrix pipes... try grabbing one of those id they're suitable
Hmm so there really should be a bleed screw somewhere then... or its a case of bad design on nissans part.Every system is pressurised mate to stop water boiling
The bleed screw allows the car to run at normal pressure and temp but let air escape from the matrix at it sits high up. In a potential air lock place![]()
