Oil cooler £70 posted
Antony
this is the one toney had at JAE only now i have a brand new mocal sandwich plate to go with it.
the sandiwich plate has two 90deg push on fitments (also brand new) braided hoses all linked up to a medium sized oil cooler (fits nicely on the front cross member)
has 2 galvenised fittings and two red and blue aeroquip/goodridge fittings.
£70 posted to your door ONO
thank you
is nobody interested in this, all you will need to do is remove the aeroquip parts from the hoses and push them onto the sandwich plate, however the oil cooler will then need to be mounted behind the engine.
longer pipes or a filter re-location kit is ideal.
Napster? you after this? pm me and ill surprise you.
