drand
1st Micraversary!
Hi
I've been away from the forum for ages what with life being on the way but I've still got my 96 P 1.3 K11.
A couple of weeks ago she refused to start entirely so I had the ride of shame on the breakdown truck back home. Diagnostic flashed up crank angle sensor fault, so i rebuilt the distributor with a new cas, rotor arm, cap and new spark plugs for good measure. I took photos while it was apart and I'm 99.9% sure it went back together properly. I marked the position against the head before I took it off and lined it up again exactly when it went back on.
Hurray, she fires up! But idle is lumpy and dies after a while. If I keep blipping the throttle to earn it up it will maintain a decent idle but when driven it does the kangaroo thing, stutters, power loss etc.
I've read threads on here and it sounds like throttle body issues. At this point I'm a bit sceptical that fixing one problem would have magically caused another to appear or reveal itself, since it was fine before. However I tried some carb cleaner, running without the various tb connectors plugged in and even got the soldering iron out and followed the micra au guide. Nothing has helped, so I'm a bit at a loss.
I suppose it could still be maf/tb but I'm not really sure where to go next. Any suggestions?
Could the tb/maf or lambda have been damaged by attempting to start when it the cas was broken, or when running badly?
Is there something I might have missed when putting the distributor back together (only thing original left on there now is the coil and the housing)?
Thanks in anticipation
Dan
Sent from my Nexus 7 using Tapatalk
Dan
