solarice
Ok well ive been searching around in the garage, and ive found a few items that i aquired during my k10 ownership days.
As ive no use for these now, figured id see if theres any interest on here.
All parts are from a 1 litre.
FOR SALE
01. K10 Airbox (Includes scruffyish filter if you want it) (£4 + P&P)
02. K10 Carb x1 (has a running problem -- cutting out, maybe needs a good clean but i never really investigated as i just bought a replacement.) (will be cheap, but no set price...so make me an offer) -- carb in pic below is now sold.
02.5 K10 Inlet x2 (just as they are...inlet manifold, both seem fine) open to offers also
03. K10 Ariel (£3.50 + P&P)
04. [strike]K10 Full Lock set -- ignition, doors and boot + key see pic[/strike] SOLD
0.45. K10 Lock Set -- 2xDoors, 1xBoot, 1xPetrol Flap + iirc 2 keys -- slightly more worn than my other set, can get pic if needed (£6? + P&P)
05. K10 Wheeltrims -- slightly curbed (see pics) good if planning on selling car on steelies.
06. Ashtray in brown (£1.50 + P&P)
07. [strike]Distributer (£10.00 + P&P)[/strike] SOLD
08. Cigarette lighter x 1 (£1.50 each)
09. [strike]Coil (£5.00 + P&P)[/strike] SOLD
10. Orange repeater lenses (1 set) (£1.00p per lens set + P&P)
11. Fuel filter (£1.00 + P&P)
12. [strike]Radiator Cap (£1.50 + P&P)[/strike] SOLD
13. [strike]Fuel Filler Cap (£1.50 + P&P)[/strike] SOLD
14. Random hosing (i think taken from rad and fuel lines -- see pics)
15. Original Nissan K10 Chrome Wheel nuts (currently missing 2 but if using locking nuts, youll be fine) Chrome on a couple slightly damaged, but for age they still sparkle. (50p each? +P&P)
16. Parcel shelf support connectors (the two plastic clips, that the rope pops over to lift the shelf when you open the boot) 60p? + P&P
17. Radiator Header/overflow tank and hoses (£offers +P&P)
18. Radiator Motor and fan (£offers +P&P)
19. Lower Radiator Hose, seems in good condition (still soft and flexable) though does have deep marks from the original wire ties...shouldnt cause any probs though. (£offers +P&P)
20. Radiator Drain Plug (£offers +P&P)
21. Fan controller thermostat (bolts into radiator), was working when last used so should be fine (£offers +P&P)
Anything that can be split i'll consider spliting.
If you spot somthing in pics i havent mentioned, let me know and i'll add it to the list.
Everything was taken off a working car, and has been stored in a padded case (exception being the rad) so ive no reason to suspect they wouldnt work again.
Larger highres images are available upon request
And finally...some have prices, but im open to offers.
FOR SALE
