Who has what? And how does it run? Not sure whether to go with something solid state or something with a larger hard drive. Opions on what you have please
thats true. I have 5 or 6 spare laptop disks. All fairly large. You can still fit windows on the solid state though, i know james has it on his EEE.
From looking at some articles Nex, it seems 100k write cycles was the case, back in 1997, now its close to 2m cycles.
tbh I use my phone for using the net/IM'ing when im out etc but I guess they could be useful for a heavy user
that 2m operations is a *full* write to the hard drive, filled with data. Calcs work out at about 51 years of activity
Anyone actually used something with an SSD drive? I know james does for sure, whats it like Jimbo?
The major advantage of using linux on a ssd netbook, is that you can define how often files are written to the disk. For example, you can define an amount of ram as a (volatile) storage space. Any log writes etc can then be made to ram, which is a) really really fast, and b) doesnt use the ssd. Then when you want to turn the ssd off, the ram storage is written to the ssd. Modern pc's have ample spare ram for this.
It is true that ssd's suffer from write wear. They use wear leveling algorithms that spread 'the damage'. Basically all that happens over the life of a ssd, is the available storage space gets smaller. The rate it gets smaller depends on the quality or how modern the design is. They are brilliant for storage, the jury is out on the root file system.
I had an original eepc. I sold it because the screen & keyboard where too small. The newer ones have bigger screens and keyboards. The original eepc could run 3d games like quake3 and such likes, due to good 3d chipsets. You can also run compiz fusion which is awesome (like aero in vista but less resource hungry).
If you buy a netbook, I would highly recommend getting a linux distribution on it, for all the usual reasons.
I wouldn't recommend getting a netbook unless you really need one.
not really a problem on a laptop.. long as the battery has charge. Long as someone posts up what their experiences is like with windows on SSD it'll give me some insight. Never used it myself yet and im quite curious.
Its main use will be for callouts with a 3G card. So i can take it places. like to a mates/family and if i get a call there's no need to get back home. It means i won't be restricted to being in the house :]. They are small and cheap, seem quite suitable to what i need it for.
