Ive read some stuff about boring a cga3de bottom end to 72.5 and put corsa pistons in. Ive read somewhere this would give a compression of 8:1. I also read you could bolt a cg13 head to it so it would be ideal for a turbo swap for a 1.3.
Is this correct? And if so from what engine do i need the corsa pistons? X12XE? And is the compression indeed 8:1?
Another question. I also read somewhere you could redrill the cg flywheel and bolt a ga16 190mm clutch to it. Is this also correct?
