That's not the right one for separate front fogs. This is what the correct one looks like if you want it OEM, which is what I did.fitted cold air feed, think it will definitely scrape now :/
about 6-8 inches off the ground :/
also if i were to buy front fogs would i need a new stalk? this is my stalk atm \/
just a quick question regarding an engine swap? if i were to buy a 1.3 engine would i be able to have a non dizzy engine? i currently have a dizzy engine in the car?also what if the engine doesn't have power steering ( mine does)
cheers guys
Those cams you found were from the 1.4 not a 1.3
The cg13de never came with coil on plug ignition, hence why your exhaust cam has no distributor drive.
Utterly unsure about the difference if any, the different inlet cam will make though.
Also you asked about the solid bar in the gearbox where the shafts go, that's the differential. It's supposed to look like that lol...
