h701micra
Deactivated Account
Thems me mounts been on before but I put em on for JayNo words needed
LEEEEEAVVVEEE ITTTTT YEAHH!!!
They're relatively simple. The hardest one is the gearbox mount.love it, how easy is it to make those mounts?? cos if its as easy as you have done to fit this it could be a smart idea for my k10, wouldnt need as many mods as you have lol, just the basic engine in, petrol pump etc and a set of those sexy mounts lol, does the front mount by the slam panel stay normal or is that one modded in any way?
If you're not intending on modifying the engine... then get a cg13 gearbox, driveshafts, hubs and brakes. K11 wishbones. Source a ga16ds from a 100nx (carb model) it will literally plug straight in or bike carbsthink im gonna need to look up a basic parts list to this conversion, to get it all in and running haha
And people wonder why I say the ga16ds is rarelol, finding a 100nx is nigh on impossible lmao, so gives me plenty of time to look haha
Or buy mine when I get my supercharged turbocharged ga16dehaha so could be looking for a very LONG time haha
You wishI have 3 in my shed... In bits but I have them
Not!
I don't use an anti roll bar on the front of mine as a short answerIf you raise the COG at just the front of the car by putting a heavier engine in (GA for example), would an anti rollbar at the front be beneficial to counter the extra roll thats generated in a corner or is the increase still capable of being accounted for by correct spring rates and damping?
What if hypothetically you raised the engine, raising cog without increasing weight? (Say to give sump clearance), because stiffer springs would upset the front rear balance no?I don't use an anti roll bar on the front of mine as a short answer
Reasons as to why are;
The centre of gravity doesn't go up much it simply moves forward. Which helps our 57% ideal front balance. The extra weight is still easily dialled in by our shocks and correct springs. Just slightly stiffer
Been sat ages thinking of everything to tell you but I deviated away from anti roll bars![]()
Correct once you start stiffening the front too much to compensate for the high roll centres you start entering understeer territory where the car isn't given the opportunity to roll enough and turn in. CoG isn't our primary concern here its 'roll centres' - The central weight pivot point over an axle. Generally between cyl 3&4 midway up. Raise that you increase the weight transferred using the basic force x distance physicsWhat if hypothetically you raised the engine, raising cog without increasing weight? (Say to give sump clearance), because stiffer springs would upset the front rear balance no?
This scenario is where you combine a bunch of soft components. Soft springs to allow roll, soft shocks to smooth and slow weight transfer but limited with a soft anti roll bar. Very similar to OE micra setups except we dont have the high roll centre necessary to require and anti roll bar
This allows us to turn in, without too much roll but is limited.. and will understeer regardless.
Many forest rally cars will use the same soft setup on the rear for the terrain but use a stiff rear anti roll bar to reduce the understeer. Except forest rally cars use a 'jacking up' type of shock setup. Where as our setups are a jacking down type where rebound us higher than compression
When done incorrectly.. you'll understeer then suddenly oversteer so there's a fine line.. personally if I was to get sump clearance I'd raise the ride height. I still have control of the crossweights and tge roll centres are unaltered
Even without corner weighting too stiff a front spring will cause understeer as you feltthat's what I felt at castle combe when I stiffened my front coil from 4/3kg f/r to 6/3kg to try reduce front end roll and thought during slow mid-exit corner it kinda understeered more.
wasn't corner balanced at the time btw
Did you adjust damping to suit?
(Out of curiosity)
Was this compression or rebound? Or both?yea I tried med/hard damping and little difference on that s-bend
Like to hear people's experiences![]()
Is there not an independent one for each. Usually one on top and one on the lower shock body?dial at the top is for both
Short, sweet and to the point I guess
Try a softer rating with stiffer springs there's less oscillation in them![]()
Look forward to the resultswill do, I'll try from min to max setting
Err noSo you finally removed all those ghastly stickers?
Or have I got the before and afters the wrong way round? :/
Alex, you clearly haven't been taking notes. This has been discussed many times. Stickers add horsepower. We need stickers on our cars becauseracecar.So you finally removed all those ghastly stickers?
Fixedbecauserallycar.
Same thing.Fixed
It is a true joystick that oneSame thing.
Just more leaves and twigs on the track. And more use of the Slidey Lever. (See, I'm learning)
Err no
There's a 7year time gap there
Definitely... unless I took the shiny stuff and replaced with dirt and rust... duhhh
Urm, I don't know if you noticed, there's a few stickers on mine..I was taking the pics![]()
Certainly haven't seen anything like it before, and I doubt I'll see one like it again to be quite honest Andy. Truly unique
@maxk11c 'our racecars'?! Where's your race car?!
I half thought you wereI was taking the pics![]()
Pfft. Where's my racecar. Cheeky boy.
I half thought you werebut I thought I'd wave the uniqueness flag again
before Nissanubaru steals the limelight
Dam these people and their common carsI forgot layla was a 1/4 mile dragster. If you can call drag cars race cars anyway...
Just show of a bit more why don't you? Subaru powered micras are common as muck round my area![]()
I've a new idea...
Lowered to the floor
Wide wheels
Stretched tyres
Now that could be a trendsetter
Oo that's innovativeAnd smoothed door handles as well maybe for the extra impracticality?
OII forgot layla was a 1/4 mile dragster. If you can call drag cars race cars
What do you reckon to 65degrees negative camber? Thats like totally new
Tyre contact patche smaller than a pushbike but who needs grip
The mega camber was my last one, shows how plain it all isCan't really think of any other stereotypes. Dayum...
Least you wouldn't aquaplane with such a small contact patch![]()
As a scene kid I find this offensive. There's much more to it than-The mega camber was my last one, shows how plain it all is
You wouldn't no but you'd not grip all that well in the first place![]()
