How did you find it before it blew up?
I feel inadequate with my t3
T3 is similar size to TD04, not much in it
Is that the saab or scooby one because from what I was reading the saab one is slightly smaller than the scooby
You need shelves or something mate?I'm going to checking out a couple of furniture charities to see if they have anything suitable
Shelves and boxes for storage but that's getting sorted next week whilst I'm off work
what you got planned for a crank sensor karl ?update
Should have a coil pack engine wiring harness, ecu and all the nats stuff next week thanks to Belly
i would try and mount the coilpack one into the g/box mate, and use an auto coilpack trigger ring on the back of your f/wAt the moment nothing but I'm open to suggestions
rocking horse poo karl (all the ones round here get shipped to germany @ £200 each, to go onto the 1.5 n16,s), and coilpack f/w and different starter under the inlet maniCould I not just use a coilpack gearbox, surely that'd be simpler
if its a compatible signal, sure, the coilpack ecu may only accept the 58 teeth + 2 missing teeth signal tho ? a standalone can probably be programmed to various hall effect or optical or whatever number of teethAhh ok.... Could I not use an aftermarket sensor and wheel or a fiat one like you suggested on cisco's?
yehWhen you say 58 plus the missing two is that 58 teeth plus the space for 2 more (60 total)?
I did. Check my blog or ask SirChris for pics. Can you get 58/2 trigger wheels? Could always get one laser cut if not I guess. If you got one custom made you could make it fit the pully better possibly.Could I not put the trigger wheel on the crank pulley rather than the f/w, would make it easier to mount the sensor
Its the way I prefer personally just shield the sensorCould I not put the trigger wheel on the crank pulley rather than the f/w, would make it easier to mount the sensor
So whats the plan karl? To run coilpacks?
I never thought I'd say this Karl but you've got me all excited!That's true it would be, but where's the fun in that
The plan is to put it into a k10 chassis once I've convinced the bank manager to let me have one
Is that to be a surprise or do we get to know your target figure?If you like that, then you'll like what I'm hoping to make.... Per ton
