This is what I'm hopingI'd put that as window open or door. Usually leaks are gradual. I've done it a few times.
Thanks Paulsince the car is parked on a cambered street tarmac normally tilting to the left, passenger side near the kerb, for water to drip down onto the drivers seat I'd check the drivers door area (door weather strip seal, windows closed, door card plastic shield fulling sealed up onto the door frame, door drainage holes not clogged & filling up & spilling into the cabin through the doorcards).
if it was parked leaning to the right, drivers near kerb, check the sunroof drain ports/tubes ain't clogged and causing water to overspill through the roof lining by sliding the sunroof back & poking long thin rod down the front ports.
best way to check the source is surround the area with loadsa water either through a car wash (but risk ruining mildreds surface & rear wiper) or wait for next monsoon or get tom to spray loadsa water from garden hose near the upper door/pillar ariel/sunroof for awhile and watch for any seepage inside.
no need to replace the foamy sunroof seals since they're always porous and let water seep through anyway.
Chris as ever .. you are a pool of wisdom :L lesson learnt xxServes you right for buying a #### Micra then. Lesson learnt?
Sent from my Nexus 6 using Tapatalk
I try to support everyone's hopes and emotions to great lengths.Chris as ever .. you are a pool of wisdom :L lesson learnt xx
Pulled your aerial up? You mean bent it/busted it so the seal now leaks?
You reminded me, I need to fashion a blank for mine seeing as there's no actual stereo in the car, not even any wiring loom either lol.
Chris as ever .. you are a pool of wisdom :L lesson learnt... I'm now of to by a corsa xx
I shall doPut instant gasket around it, or bath room sealant
Or burn the car to the groundI shall doxx
Yes I can imagine it will be doable in the next few months with no issueHaahaa you do make me chucklewell have to sort meeting up at some point
xx
That would be alot easier :L xxOr burn the car to the ground
The front one xWhich Ariel was it?
Sent from one of Jupiter's moons using Tapatalk
How the fek did u let it be that much out lolTyre changed and tracking donedrives a dream!
She was three and a half degrees out! :O
X
Damn.... Lucky it didn't do some big damage really!! :O
Well like i said god knows how I didn't notice :L she drives like a new car now :L
It never pulled which Is probably why I didn't notice like I said just every so often would snatch but I just put it down to the roads TBH, the worn tyre and the change in weather :L
Hey ho!!! All sorted now ehhxxx
