frank
is the 1.3 and 1.0 non nat ecu the same?
yes pritz, tho micra_pete and baguete said that the 1.0 has more total ignition advance iirc
anyone got a 1.3 non nat ecu for sale?
tried another ecu today and the problems still exists
what sensor can cause this?
ive taken the car to a diagnostic centre and even they cant seem to find the problem i gave them the car they charged me £120 and got my car back exactly the way i sent it there
basically there is a pipe from turbo to actuator i split it added a t piece and plugged it to the boost controller. The boost controller has 2 pipe slots only 1 is used and with the other im sure it stays as it is
should i remove the controller then? i fiitted the emanage myself but not its removed ut still doing the same thing with the emanage do you think it could be the boost controller?
yes ive checked for a boost leak also i noticed than when driving today (car cutting/running rough) i drove into a ditch on the road and car started running fine again until i got back home
Is it an actual walbro or an eBay copy?i thought it was fuel pump and ive changed that a while ago to a walbro 255
on the left side of the throttle body there is an adjustment what is it for?
this is how the car is running now http://www.youtube.com/watch?v=3itzG85-pLw
its holds between 14-15 when driving doesnt run lean anymore but theres alot of hesitation does it seem like the distributor needs adjusting?
what are you using to adjust the maps?
im using a walbro 255, fpr set at 30psi and standard throttle
emanage is already removed so standard ecu with 1.6 injectors
What is the timing degree for the micra?
