hello, to you turbo owners and builders
Im suffering severe boost loss with my car.. the turbo spools up as it should, it reaches full boost around 3.5k Rpm then the boost is lost, its very sudden..
When the boost is lost the car has no power at all..
I can build the Rpm quite High with only slightly touching the throttle in order to keep the boost less than full and the car pulls nicely, Albeit with much less force..
Its definatly not a loss in the intercooler piping and couplings as ive tested them all... several times...
the Loss of boost it quite instant.... taking less than a second.. from 0.8bar to nothing..
Could this be the actuator or somthing else..
Ive been on the RR again and the car powering up and developing 108bhp repeatedly at the fly until boost loss ( 3500/3800 ).. then the power drops completly..
It Started all of a sudden and has been constant ever since..
Also.. There is No wooshing noise like its been dumped through the Dumpvalve although its lost JUST as quick..
Possibly the Dumpvalve????
Ideas???
Id love a solution before sunday night as im attending the RWYB at Santa Pod on monday..
Ideas???
