Micra battery
Hi all, can't get my Micra to charge, the battery clip is too big for the post so I've had to make up a lead sleeve for the battery, it's obviously not the right clip for the battery so if anyone knows where I can get a genuine postive battery clip I'd be really grateful
Regards
that sounds like a big ass batery you got
make sure your car can take its ampiage-then make it fit but safely and solidly clamped in the tray(custom top clamp)
To be fair if it is the correct one then the leads would fit unless the previous battery was incorrect and the leads were changed. May i suggest you check with the supplier.
