CMF_Mickb
» CMF MemberHi all,
time for a build thread from me, perhaps if I make a thread about it, I will keep it long enough to enjoy it. I've owned 4 (now 5) micra's - this won't be the last I'm sure.
OK Super S gone, LX is in.
Current spec:
95 LX in white.
Whiteline Swaybars Fr Rr
Whiteline droplinks
Whiteline Panhard rod
Whiteline Castor Kit
BC Coilovers w/ Swift Springs 10kg/9kg
I have many sets of springs, might swap once it is setup.
Disc rear axle
N14 GTIR front brakes
Nology leads
Nismo engine mounts / solid engine mounts/ HD powersteering mounts
HD clutch - will install when GB work gets done
3.6kg Flywheel - will install when GB work gets done
15x6.5 forged gold rims - 195.50.15 Toyo R1R
15x6.5 SSR Forged black rims - 195.50.15 Toyo R888
Nismo rear wing (not sure if I like it, cbf removing though.)
Replacement timing chain
296/280 10mm lift cams
p/p head, HD valve springs, Ti retainers
ARP head studs
N2 0.3mm Head Gasket
Mulholland cam gears
Bits to go on/in progress:
Nismo N1 Exhaust system
Current spec:
95 LX in white.
Whiteline droplinks
Disc rear axle
Nology leads
ARP head studs
