Hi new to the forum but hope to get some help/advice, I have recently purchased a super low mileage 3k virtually 1 owner 1993 1.0L. I managed to drive it back to my home probably about 70 miles. It was difficult to start but did eventually and would struggle and occasionally die all the way home. I have sinced changed Dizzy cap and rotor, Spark plugs, Ignition leads and fuel filter. Have drained a lot of the fuel out as not sure how old it is and put a couple of gallons of super plus in. Still the same doesn't want to start but does eventually, will then idle but occasionally dip in revs and if you floor it doesn't rev and will try to cut out, but will rev if very light on the throttle. Also the exhaust has some rusty water coming out when running, was thinking possibly a knackered catalytic converter ??? Apart from that it is as it left the showroom so really want to get it running right. Thanks for any help
