Limited Slip Dif compatability
Hey all,
Forever lurker from Australia with a question.
Can the 1000cc march k11 gearbox (RS5F41A) NISMO 1way limited slip differential fit into the the 1300cc march k11 (RS5F30A) gearbox? I have bought one without thinking or checking compatability.... bloody idiot that I am.
Any info and explanation of options available to me for using the LSD would be greatly appreciated.
Frank, does that mean it wont fit in a 30A gearbox at all, or that fitting it means installing different diff bearings and custom cv shafts, or 1L standard cv shafts?
Is it possible or should I walk away from the purchase if my only option is to use my 30A gearbox?
Im currently throwing 165Hp with my turbo setup and am tired of single wheel spin.
Yeah thanks Frank. I figured as much. I'm gonna determine which engine it comes from once it arrives, then resell it to UK market if appropriate. Hopefully it wasn't built for a one of a kind NISMO box or some nonsense.
it was the viscous diffs that had the oddball casing eh, iirc the nismo one is a direct fit to the stock casing
