After fitting the 1.3 fastroad cams that i just bought from Ollie it appears that the valve clearances were ranging from .75 to .85mm, didnt consider it a problem just measure up and get correct replacements from nissan easy........
although it apears i have the same style of shims as the cga engine.
A solid bucket shim with no numbers top or bottom, can i get replacements for these if so i take ill have to measure up with a micrometre??? Please help!
Oh and thanks for bringing the cams down James! :grinning:
