Antony
GRRR
the raceworx head and advanti cams are no more....
after realising that the "chees string" timing chain i baught was exactly the same length as an origonal, and then trying to turn the cams..... i found thatthe inlet cam was very very tight..... compared to the exhaust cam that is...
so we tok the cams out and found scoring around the end cap bearing faces on the chain side of the inlet cam and on the head too.... plus the cam has a groove in it now and is totaly fudged beyond repair... :down: :down:
so im now gonna fit the standard head back on with the standard cams and just run the janspeed and de-cat......
im so dissapointed as i was looking forward to having an N/A screamer.
i may put it back together... get it running and flog it...... i think ive had just about enough.... ive had the head off three times now... and its getting expensive.
any ideas guys?..... bearing in mind i am totaly skint and i need my car for work.. (plus ive put about £4k into this car so far...) fwn :down: :down: :down: :down: :down: :down:
