****e site... Money grabbers
Try 0680Would anyone possible know my code please? BP538469482038
I Can't find it anywhere
Try 7435 or 1435Hey man! Do you have a code for me too?
BP334958129926
7643439318
Thanks in advance
Try 8016 or 0016can anyone help me with the radio code for my girlfriends 06 Micra
serial number: BP538769679012
7645387318
Try 2589 or 0589Hi, I hope someone can help me with radio code for my Micra
The serial number of the radio is BP234631980445 model 7642346318
thanks
Luka
Try 4521 or 0521Would be over the moon to get the radio code for a 2006 K12 Nissan micra please
BP334947342556
86351233920
Many many thanks in advance!!!
Try 5295 or 1295Hi hoping someone can help alleviate the boredom of a long car journey with a code for my radio.
Micra k11 1998 1.5D
BP6340W4216666
7646340318
Thanks in advance
Try 9055 or1055 think that's cleared the backlog of requests ;0)Hi John (or any who could help)
My car recently came back from servicing asking for a code
The serial number is BP538761152147 and the model is 7645387318
Could someone help me get the 4 digit unlock code please?
Teifion
Thanks John, will test it tomorrow!Try 4521 or 0521
After locking the stereo and having to leave the ignition on for over an hour, finally got 4521 to work!Thanks John, will test it tomorrow!
Try 9993 or if that fails 1993Hi,
My serial number is : BP234631973343
part number is: 7642346378
Can you provide the radio code ?
Best Regards,
Kiril
Thanks for the quick response man.Try 9993 or if that fails 1993
I need the number, starting with BP then twelve numbers, to decode the radio Estelle, it should be engraved on the side and/or the back of the 6 CD player (well it was on mine)Hello
I have a 2005 micra and had to change the battery recently - and now the radio/cd player is asking for a code. I wasnt given a handbook when I bought the car and dont have a code. It is a factory fitted radio/cd player and not sure how to get it out to look for a model/serial number. The only number I have found is 55610190794 but not sure if this is the serial number.
Hope someone can help please
Estelle
Hi Raul, try 1792Hi,
My serial number is : BP536158176603
part number is: 7645361318
Best Regards,
Try 4781 or 0781Hi John
Wonder if you can help me with a radio code for my little Micra? The BP number is 334958122505 (Blaupunkt). Cheers!
Hi John, having seen the previous posts it seems you are the go to for radio codes. Could you please provide a code for my granddaughter's Micra?Try 4781 or 0781
4781 it is!! Many thanks, JohnTry 4781 or 0781
Try 7844Hi there,
Daughter's just bought her first car...1996 micra, but we don't have the radio code.
The serial number is BP6340T3155179
parts number 7646340318
If anyone knows the code that would be brilliant.
Hi Jeff,Hi,
New to the forum after buying my daughter a 2004 1.2 SX, would appreciate a radio code from one of you fantastic people if you've got the time.
BP234631992693
762346318
Would really appreciate the help as teenage daughter with no music isn't pretty, thanks in advance.
Jeff
Hi Dave 5512 or 1512 should do the trickHi John, having seen the previous posts it seems you are the go to for radio codes. Could you please provide a code for my granddaughter's Micra?
The serial number is BP5365 5 6444441
Thanking you in anticipation,
Dave
Not had a serial number with a letter in the middle before , but seems to decode OK, try 7649 or 1649Hi John
Any help will be greatly appreciated
- Make Nissan
- Model Nissan MMR#2 CD-G
- Part Number 7 647 383 318
- Serial Number BP7383A9254345
Thanks John, that did the trick!Hi Dave 5512 or 1512 should do the trick
0518 would seem to be the answer to your prayersHi there,
Need the radio code for my micra!
Serial number is: BP3349 47305283
Part number: 7643349318
Thank you!!
Hi Raul, try 1792
Try 7233 or 1233 (write the working code down somewhere and keep it somewhere safe)Hi flat batt again i have lose my radio code it would be great if you could help me the numbers on the radio is BP538469506633 the next numbers is 7645384318 ?
many thanks
Thank you "7233" my radio working nowTry 7233 or 1233 (write the working code down somewhere and keep it somewhere safe)
