Hello Everyone,
This post is my last resort before going to a car electrician.
My car's fob started lose its signal months before, and currently it is in a state I just leave the vehicle open and hope someone steals it, because financially it would be more beneficial.
The actions I did so far:
-Cleaned the circuit of the fob
-Changed battery in the fob
-Changed and resoldered new micro switches into the fob circuit
-Called 2 different locksmiths, and both confirmed the fob is perfect
-The first locksmith even programmed my fob again
-Made and programmed a new fob by a locksmith (although this time car programming was not available, I did also try, without success)
-Disconnected the battery 30 minutes
The central locking button works perfectly, and the door lock sensors as well (no faulty open door red lights on the dash). Additionally the inner lightning comes up synchronized as well.
Fuses are OK, although I did remove them for a while and reinserted.
No faulty codes from OBDII scanner.
Currently the car remote only works if I point the key from the inside of the car to the heating controls in the middle.
Any advice what could be the reason?
For replacement parts, what should I search for?
Hoping in your answer,
Bereny
Bereny
