Dear All,
Would like some assistance please.
I have a 2003 Micra K12 with keyless entry.
I noted that after around a week of not driving, the battery goes flat. I have gone through a couple of batteries already. Even if I disconnect the radio, same issue.
Battery health check performed and charging tested, all normal.
Door switches and lights all checked, all fine. Boot lid switch checked and all ok.
I also note that the remote fob locks and unlocks the car (from outside), the car starts fine (key recognised) after brake pedal pressed, however I noted that the door lock switch by the handbrake does not lock or unlock the car doors when sitting inside and doors all closed. You can hear the clicking from the relay in the body control module when the lock / unlock pressed from the button, but nothing from the door actuators. I opened the switch and cleaned the contacts.
Checked the Haynes wiring diagram and cannot find anything suspect in the circuit, apart from the obvious Body Control Module.
I am not sure if there is a fault with the body control module or not? I read some forums stating that the K12 has a common issue with ECU / BCM software. But not sure if this would cause a battery drain and central locking issue.
Any advice is much appreciated.
Thank you.
Thank you.
