K12 Radio Codes
Hello,
The battery recently went flat on my 2009 Nissan Micra. I have removed the radio to get the serial number:
PP3000MB 0009750
Please send me the code
Hello,
PP3000MB 0009750
Right place, but sadly the wrong radio, I can only supply codes for radios made by BlauPunkt and the 'PP' prefix suggests that yours was made by ,I think, Fujitsu (CL is Clarion and DW is Daewoo who also supplied radios to Nissan) ?
K12 Radio Code Thread
This is the official thread for K12 radio codes.
Please provide your serial number (starting with BP) in reply to this thread.
Please bear in mind that the generous people that provide these codes do so in their spare time so please be patient when requesting a code.
My Nissan micra k12 radio serial number is : BP538464179511
Ok , joking aside I suppose I had better find an unlock code for this :LOL:
The answer to your initial request would appear to be either 9526 or 1526..........(which would have appeared quicker without the 'hurry up' second prompt......... ;))
Hello
Nissan micra k12 2004
863512364201
St-SN
Please help me!
Thank you
Well if the 12 digit number that you posted above, came off of the radio and started with 'BP' then the code is 1952, however if that isn't the case you need to remove the radio from the dash and get the right number and we will try again......
Thank you very much,
I will try this code, on the corpus only write this number.
Hi there, thanks for taking the time to help me. I have a 2008 micra k12, how do I find the BP serial number in order to get the code? I can’t find the answer anywhere online, if anyone can help me I’d really appreciate it! :)
The 'BP' serial number is engraved on the side and/or back of the radio (assuming the radio was made by BlauPunkt and not Fujitsu, Daewoo or Clarion). If your 2008 K12 has the standard radio/multi CD player, without Bluetooth, then it will be a BlauPunkt unit. Google video's for 'removal of Micra K12 radio' and you should find a easy to follow guide.....
although I’m sure it is the original 6 CD radio, it appears to have been made by Fujitsu. I can’t find anything anywhere to help me. The serial number is DEB0201359. I feel like there’s no hope ?
Well if it looks like this:-
it is the BlauPunkt made unit
This (with Bluetooth) is the Clarion one........
And Fujitsu make this one (though I didn't think it was fitted to UK market cars).......
Which is yours?
Mine is the last one, which makes sense as I am not actually in the uk. My car is Australian, thank you so much for your help though and such quick responses, I really appreciate it
Makes total sense, seems to be the standard fitting for the Australian market... THESE people in Queensland seem to know all about them and may well be able to give you an unlock code from the serial number....
Hi Very helpful site...hopefully you can help us.
We’ve a 2009 micra n-tec and need a code to unlock the radio following flat battery
Serial number 3133717
Device number 7612830023
Thanks in advance
Hello,
The battery recently went flat on my 2003Nissan Micra. I have removed the radio to get the serial number:
BP234621248618
Hi guys,
Hope this community is still live and kicking. Quick question for you all..
When the radio is not allowing me to enter a code and is showing a go to dealer message then is it lying to me or telling me the truth?
Much appreciated.
Sweaty
Hi guys,
Much appreciated.
Sweaty
Depends on the radio, but likely too many wrong attempts have been made to unlock it and it has totally locked down, so main dealer may be the only alternative, though a good automotive radio specialist may have the necessary equipment to unlock it......
Hello,
BP234621248618
Hi, the magic number that you need appears to be 0214........
Thanks!
It's a clarion one with the big display.
There is a message that says something like too many attempts and contact dealer.
I guess it's one of those £35 dealer jobs that takes minutes to do
Anyone help with this code. The one I was supplied didn’t seem to work.
Hi can someone help please, battery went flat and now require a 4 digit code.
BP3349 4 7342329
Ten digit code is 7 643 349 318, unsure if this is required but I've seen some people include it.
Thanks in advance guys
BP3349 4 7342329
Hi, the answer to your prayer would appear to be 1044...........
Hi I had to replace the battery on my 2007 micra and the radio is now asking for a code can someone please assist me with this the radio is a Blaupunkt
815BP5388 6 2390074
Nissan MMR IDC-T
7 645 388 618
That’s all the detail on the Radio
Thanks your help would be greatly appreciated
815BP5388 6 2390074
Nissan MMR IDC-T
7 645 388 618
Hi, try 5033 or 1033.........
Hello guys...can u please help me whit a 4 digit code for my micra
BP 234746059749
i think model is 8 635 123 392.0
St SN
THANK YOU VERRY MUCH
I am sorry I can't find where I should post my question. My radios serial is BP234732037391 and I think parts number is 7642347318. Thanks in advance
Well you have found the correct place and posted the right information, so I'm pleased to say that your unlock code would appear to be 8741 or 0741......
Hey there!
My Micra's battery drowned (silly me)!
The magical numbers are
7 642 347 318
BP234732037170
Please help me, i fond music while driving! :)
Hi all
I was hoping someone could help with a code for the below. It's a 2014 Micra Special Edition.
Would be very much appreciated. :)
HY67N04778
PART 281853HN4C
PROD DATE 16/07/18
Many thanks
James
