K12 Radio Codes
Hello, The battery recently went flat on my 53 plate Nissan Micra. I have removed the radio to get the serial number: BP334936377873 Can anyone help with the radio code please?
Hi, the code that you need appears to be 1358.....
Hello, help please . I have removed the radio to get the serial number: BP738398785308 Nissan MMR 2 CD g 7 647 383 318 Can anyone help with the radio code please?
Hi all, I lost my radio code and needs to be put in due to a battery change. Serial number got after 3 wrong attempts is DW49N20486
Could anyone help please? Thanks!
Hi, had you read back further in this thread you would have seen that the serial number required to supply an unlock code starts with 'BP', which signifies manufacture by 'BlauPunkt', which I can decode. Sadly yours starts with 'DW', which signifies manufacture by 'Daewoo', which I can't supply a code for..................
Nisan 'Main Stealer' may well be your only option......at a price....
Like everyone else I seem to have lost my radio due to flat battery. I cant find any codes starting in BP the VIN is SJNEBAK12U2244452 - it is a 2007 model. Can anyone help or tell me where I can find the BP number?
G'day Belinda!
Read this => micralife.co.uk/K12/stereo
Hi im new here joined today. Seems like everyone does a great job with helping each other out so giving it a try too..
Needing a radio code for my blaupunkt radio..
Struggled to take it out the car today but did it finally ?
Bp234746055584
7642347318
Help really appreciated.
Thanks Francesca
Hi havent posted before so not sure if im posting in the correct, latest thread..
Need nissan radio code please
Bp234746055584
7642347318
Help appreciated
Thankyou francesca
Bp234746055584
7642347318
Help appreciated
Thankyou francesca
Hi, yes in the 'correct' place (and with the right information):). Try 7157, or 1157.......
Hi,
I've had to change battery for my mothers Micra and despite having a mountain of history, the radio code escapes us!!
Car is a 2005 1.4 Micra
Radio has serial number BP334958128119
Thanks!!
(Hope this is enough info?)
Hi,
Thanks!!
Hi John, hope this is enough info for you?
Dan
Hi there,
I have managed to get my locked radio out, but could not find a code that started with bp. I did find one under the barcode but did not start with a letter
314083325915BH10D. D 0224 009 013 200
I also found a bosh part number 7 612 830 023. And a Nissan part number 25915BH10D
My car is a Nissan. Micra dci 2010 it has the sat nav and Bluetooth built in also.
Are you able to help with an unlock code please or some advice as to where I need to go.
Thank you in advance
Hi there,
Sorry, as far as I know the post 2010 sat nav units (even BlauPunkt ones with a 'BP' serial number) can only be unlocked by a Nissan main 'stealer', with of course the obligatory wallet wrenching cost.:mad:
I have a 2010 k12 ntec dci, it has the connect sat nav bluetooth multimedia thingy. below is a pic of the radio code, might help anyone struggling.
Hi,
Can I please have a code too
BP5383 6 9449330 PN 7 645 383 318
Now fed up with the of 1/4/on eject trick. ;)
Thanks in advance for your help.
Mike
Thanks for the reply John, I’m guessing that these online “pay us for a code” wont be any good either so may have to go to main dealer :-(
I typed it in but unfortunately it didnt work :-( , I’m happy to try any other codes that anyone has.
Can you help me with my Nissan micra radio code please FBAK12U1379771
Please read some of the earlier posts in this thread to see what information is required to generate a radio unlock code...... (I'll give you one clue, the VIN number of the vehicle is not it, unless you are a Nissan Main Dealer...)
