Changing the plugs recently, one plug is just 'spinning' in its threads - will not tighten or indeed loosen any more than it already is to remove it.
As the plugs are recessed in the 'tubes' this is creating a bigg issue for removal.
Are the 'tubes' an integral part of the cylinder head or can they be removed themselves - maybe by removing the rocker cover?
Any simple & cheap ideas on removal of the stuck plug in situ - don't fancy removing the head?
