If you have keep fit windows you will need to carefully release the horseshoe clip on the inside of the window winder, make sure you have your other hand over it otherwise it will spring into space.
Pop the clips out along the bottom and up the sides then push the trim up to release the top edge.
Keep the trim as flat as possible when popping the clips out. If you bend it too sharply the panel releases and leave the plastic clips in the door.
