Original thread - http://www.micra.org.uk/showthread.php?t=2890
I was recently advised by a custom exhaust & maniflod designer & fabricator that; for the case of a 1 litre engine...if the custom pipework is anything greater than 1 3/4 inch bore, then your N/A torque will drop off (due to reduced back pressure)...however fitting a greater bore pipe will allow greater torque gains if you are boosing (with either super charger turbocharger or Nos etc..)
Does anyone have an oppinion on these comments?
ALSO,
There has been many discussions on the differences between the MA10 and MA12's.....but what ar the main differenced between the MA09 and the others......in particular the engine bits I am interested in for example pistons, block head gasket, head, mantfolds, clutch, gearbox driveshafts....(not the super and turbo charging bits)
Cheers All
you will only go through gearboxes if you mistreat them
MA series with 4 branch exhaust manufold, full system, aftermarket air filter and a weber carb? In my opinion, its no better than a bog standard MA10 engine, except its not as smooth, louder, worse on fuel and looses its bottom end torque.
IF you want to go fast, simply get a faster car, or put a bigger engine in.
ALSO,
Cheers All
