I have read that the K10 box is weak but I would really like to understand the modes of failure (i e what ypes of breakage occur and how it happened)
My particular interest is in the manual 4 speed
1)Do they fail mainly because they are crunched or short shifted under high torque conditions?
OR
2)Do they fail mainly under “in-gear” acceleration…but the torque gets too high
Also for either case; is the ‘strength’ of the K10 gear box significantly effected by normal wear due to high mileage….or is it just plain PAP even when new!?
If the case is that “they fail under normal “in-gear” acceleration…does anyone have any info on which gear is the weakest over the others and what sort of torque the box will pop at in that gear (and / or load)
I guess this is subject is not straight forward and has many dependencies & variables…but any solid info / case examples would be appreciated….
For example if you have had a box death….what were the circumstances (power / torque / driver behaviour) and what was the care history of that box
Cheers to anyone who can help me here…
OR
