many people who drive my car have struggled yet i havent (tends to be the people who drive newer cars) i do sometimes have this problem with reverse though but only when the engine etc is cold.......
maybe your oil is too thick stani ? some members have said theirs were stiff after a g/box oilchange ( mine has engine oil in lol)many people who drive my car have struggled yet i havent (tends to be the people who drive newer cars) i do sometimes have this problem with reverse though but only when the engine etc is cold.......
yeh, haynes says 80W, but thats damn thick for a modern g/box imo, bear in mind all the millions of austin mini,s etc that were designed where the g/box doubled as an engine sump, and they ran ok on dirty engine oilreally? ive never changed it yet
pretty much all Hondas use engine oil in gear boxes! I'd personally not be comfortable putting regular oil in a gearbox that's designed to use Extreme pressure (EP) oil thoughyou can really put engine oil in a box frank? didnt know that
if you,re munching gears like dave bull (or maybe polly ?) then shear strength or EP properties are probably critical, but it seems to be the bearings that eventually fail with members (where shear strength etc dont factor imo)pretty much all Hondas use engine oil in gear boxes! I'd personally not be comfortable putting regular oil in a gearbox that's designed to use Extreme pressure (EP) oil though
nope autodata just says engine oilYes, Honda gearbox oil has the same grade as normal engine oil, but dont know its properties, must have something else...
Does anybody got a picture of inside the gearbox? To see if there is REALLY yellow metal bit inside it actually? Because we are told to put only GL4 but stores only have GL5 these days...
http://www.mobiloil.com/usa-english/motoroil/car_care/askmobil/GL-5_and_GL-4_Gear_Oil.aspx
