the GA16 ones made mine hard to start tom, but some say they,re ok, and 5 bar is a lot of pressure
5 bar is double standard pressure. i dont think the injectors can take it though so im gonna put larger capacity injectors on and lower the pressure. more fuel big bang! what about sr20 injectors or ca18det?
Frank did you have to fit resistors for those injectors? Im awaiting news for the price of my rb25-cg rail getting welded before i rethink my options
Ok and what cc are the qg's? I think i have 315cc on the rb25's
Frank, what power increase did you see from putting the ga16s in? was it significant? what fuel pressure do you run at?
I don't understand why people want to change Micra injectors? It adds NO power??? the oem ones are large enough as it is, unless your running a turbo.
i better fit my stock ones back in then ed fwn
At least someone said itI don't understand why people want to change Micra injectors? It adds NO power??? the oem ones are large enough as it is, unless your running a turbo.
aye, red herring FTW
If you're not adding a correspondingly larger amount of air to match, adding fuel will achieve nothing more than sooty plugs and poor economy, Ed's right fwn.
Is that with the sr20 throttle body frank?
5-6 psi would be ok on the standard injectors wouldn't it?
Frank You're ecu (in the nicest way possible) has no idea what's going on,
even though it recently passed the emissions, averages 70+ miles on a tenner, and does 15.4 sec 1/4 mile :grinning:
