Think you may have your btdc and atdc switched AndyThanks in advance... excuse the pun eh
The ma10 is a fast burning engine and doesn't require much timing retard if any.
Put it at 0 btdc
Put it in 4th @ 30 mph then put your foot hard down
If you hear pinking reduce your timing to 5btdc
If no pinking is heard set it further in advance.. 5atdc is your max
Do I :/Think you may have your btdc and atdc switched Andy![]()
Only on that post though... you're supposed to set at 5 atdc then advance 1 deg at a time no?Do I :/
Ooohhhh yyyeeeaaahhh.....Only on that post though... you're supposed to set at 5 atdc then advance 1 deg at a time no?
