Baz
Right basically when the car is sitting at traffic lights it likes to stall,tryed 2 different working airflow meters,3 idle control solinoid things(3 screws on it)replaced the cold start solinoid.
I have a narrow band lambda reading function on the turbo-timer I have that use to read 14.7-14.8 Afr at idle and cruising off boost before all this happened.
Now the car revs up and goes rich 12.5 afr, and obviously the ecu trys to regulate this by bringing it back to 14.7 but instead starts hunting and cuts out.
I'm at my wits end here with this bloody problem,I'm thinking now it may be the injectors or something to do with the e-manage?
