Hello there, quick tutorial, dont have much time
Heres your work plan
discription is for RH seat (in UK is a drivers side)
first -Dismount Suzuki seat rails, cut the middle mount with grinder
1- bolt the rail to body, to stock Micra seat mount
2- bolt this cut piece to body
- fit some metal to join these two pieces
(see picture)
Mount number 2 complete
-Now- cut mount number 4 for easier work
-Mount Rails to the seat for further fitting
-instal seat with previously made mounts at left rail
important- check how it fits, put somenthing under mount number 4 for leveleing the seat
3- Now- Drill an hole for mount number 3. Nut and bolt is easiest way to mount this one
4- mount number 4 that you cut before- bolt it to body and made some metal fork as seen at foto. I've used my fav material
(see picture)
