Brilliant Ed, I understand much better - thanks a lot.
I phoned Nissan earlier and asked them and the mechanic said he wouldn’t comment and would charge me £42 just to have a look at it and plug in his fault code finder. I told him I’ve heard you can get this error code by using just a paperclip and he said well if you do that then you’ll render the ECU dead. I’m going to try Eds method in the bottom two sockets – hopefully tonight – and then I can see if the ECU knows about any errors. I’m hoping its just a sensor, a cheap one at that.
