My son has a 1993 K11 which is blowing the fuel pump fuse. I've bought a replacement pump, but thought I'd run it before fitting into the tank. I've run it semi submerged in parafin for about 20 minutes (to bed it in as it were??). I was amazed at how hot the pump got (about 50 Deg C)!!!
So my questios are;-
1/ Does this pump run continuously once the ignition is on, or does it run "on demand" when the management system calls for fuel??
2/ Also as the pump, when on test, wasn't submerged (as it would be when in the fuel tank), has this allowed the temperature to rise so much?? i.e. does the fuel in the fuel tank keep the pump cool??
3/ Have I bought a dodgy pump??
Thanks all.
Thanks all.
