Sorry to post on such an old thread, but as an answer to the question why VW have put the turbo after the supercharger. I think it is partly because when the heat flow rate of the exhaust is high enough to spool the turbo and create sufficient boost, it then turns the supercharger off with a solenoid clutch thing and just uses turbo, which is more efficient as turbos recycle energy. Having the turbo after creates a more direct air root and less pressure loss at high rpm (motor way).
In the case of the micra st they use both turbo and super at the same time for max boost opposed to just turbo for max boost like the VW. The key thing about a supercharger is it is easier to create "relative" pressure increase with high input pressure. i.e (Pout=Pin+Work done*effective area) so it will always increase the pressure of the substance running through it assuming it is engaged and that work done>Pin, so in the case of the ST putting the sc after the turbo means both are creating positive pressure differential through more of the rev range creating more boost but also using a bit more energy for work done on the sc.
This probs make no sense to anyone just thought i would give my pennies worth.
