G
gfunk
Hi,
I, along with 9 other fortunate chemical engineers have been performing quite a number of tests with quite a lot of small engine cars recently, as well as high performance sports cars.
For contractual reasons, I can't provide car brands; but under all conditions, no performance betterment was experienced. Fuel will last slightly longer, due to higher efficiency detonation - but there is no performance advantage whatsoever. It was thought that performance-based usage of high-octane petrol was a major reason for customers purchasing it; but it would appear that this is only perceived performance, perhaps due to a smoother drive, due to less eratic engine operation. However, this smootheness incrase is only slight.
These results are also appropriate for this website, if that helps you perhaps understand one brand/model of the many cars tested!
Once published, there will of course be advisory terms stating that high octane petrol is definitely better for your engine; causes less wear on internal engine components. However, it is not a wise investment for any non-sports car, or non-rotary engines (ie: rotary engines are only utilised by a couple of Mazda models nowadays), unless you enjoy spending extra money for no particular reason.
Regards.
Regards.
