J
Jazzy_Jefferson
Hi all
New here, so alright! Mate has sent me an e-mail and i thought I'd put it on here to help solve his problem.
Got a problem with my micra, and i cannot work out what it might be.
Basically, when i start the car and drive, its fine. when its warmed up it will begin to sort of stall, or cut the fuel or something. when cruising at 50 the other day in 5th gear, i had my foot flat to the floor and then lost power, so speed dropped a bit, then i re gained power and sped up, then lost it, then gained it and so on. all the way home. for some reason, it only does it when warmed up and when im pushing on the acclerator. doesnt seem to matter how much pressure is applied to the accelerator either. the loss of power is very jerky, like its almost stalling, however it doesnt matter what gear im in. it also does it when stationary, you can hear it struggling, and then it will stall. Maybe ignition timing or something?
I have cleaned the spark plugs and HT leads. other then that, no idea what it might be. could be fuel pump, but why doesnt it do it from start up if thats the case? You can see i clearly know very little about the micra.
So you know, its a bog standard '95 1.0 micra tropic. in white. fantastic!!
Hope you can help, cheers guys.
Jazzy
Jazzy
