help with boot/ feul cap release
i bought a boot and fuel cap release and cant figure this out :confused: (i think its too early) where do i run the cables
pic would be helpful :)
They go from the passenger side handle location, accross underneath the backseats, behind the passenger rear trim panel while passing through the metal cutouts into the boot. From there it splits into the main latch for the petrol door, and the rest goes to the boot latch location.
That make sense? :D
i have done a bit of a write up on this a while ago
http://www.micra.org.uk/threads/aftermarket-boot-fuel-remote-release-fitting.49459/#post-508484
the remote lever is obviously mounted on the drivers side the cable then runs under the back seat across the floor to the passenger side then over the top of the rear passenger wheel arch to the fuel release then onto the boot locking/ release plate
