I have a K11 micra, whenever i need to fill it up the handle on the petrol pump clicks off as if the tank is full. Im guessing its because the air pipe is blocked.
Had a rumage around in the boot and found a pipe about 5mm. Black pipe going into a clear one, is this the correct pipe? it seems to go under the passenger seats and towards the front of the car.
Any help will be appreciated, its really annoying takes ages to put fuel in! grr
