Hi all
Having just replaced the front crossmember and sorted the brakes the car flew through it's MOT.
However, it seems to be using a fair amount of fuel as of late and also doesn't run quite as smoothly.
I would appreciate any advice on how to check the fault codes.
I also own an MX5 which is easy to get the fault codes out of it by shorting the connector and counting the flashes of the light. I presume it's similar on the Micra. 1 Short Flash = 1 unit and 1 Long Flash = 10
Does anyone know where the diagnostic connector is? And can anyone tell me what flashes corresponds to each fault? I have a table to read off when checking my MX5.
Many thanks in advance
Paul
Paul
