Hi everbody!
I'm Daniel from Finland, and i drive a Micra K11 1.0L CG10DE pre-coilpack -1999 with NATS. Recently, it has given me quite the headache.
It all started when i accidentally flooded the engine two weeks ago by accidentally depressing the accelerator when starting. After solving the flooding issue, (by pulling the fuse and running it dry), It has developed an extremely difficult idle problem.
Basically, the car jerks under acceleration, and the engine light is flashing when this happens. Also, the idle sounds a bit off, jumps up and down, and it wants to stall (but doesn't!)
Things that I have tried changing:
-Sparkplugs
-Distributor cap
-Rotor
-Distributor (Brand new from japan! 170£ ouch :S)
-Resoldered the throttlebody according to the well known guide.
EDIT, also tested:
-Cleaning the MAF with CRC MAF-cleaner
-Cleaned the Idle Air Control unit with carb cleaner
-Checked the fuses for corrosion
-Replaced the O2-sensor with known working
-Injector Cleaner
-Replaced the MAF; TPS and IAC
-Changed the fuel filter
-Changed the fuelpump (Expensive as &%/)
-Drained the tank (to purge water), no change
-No check engine codes are stored
None of the above has been any help, and the car still gives me trouble. What should I check/replace next?
Thanks!
/Daniel
-Sparkplugs
-Distributor cap
-Rotor
EDIT, also tested:
-Injector Cleaner
Thanks!
/Daniel
