i just cut one off one off in scrappy and solderd it on or use them block connector things
Does anyone know which pin that is? If its the earth pin that keeps melting, it means you have a bad earth (poor earth means high resistance and melting the connection) and need to unbolt them and clean them up with a bit of sandpaper.
Or I could be wrong and its the heat of the bulb, but it would be a bit odd that it only melts 1 connection.
