it's in the members section, but the haynes manual will also show you how to remove your dash cluster.
Remove steer wheel cover at the back, 2 screws and the front clip on the ignition barrell.
Then remove the screws for the cowl and lift it off, then you can remove the 3screws holding the dials in.
